New to dirt bikes
Ok well I just picked up this project the other day and was wondering what kind of bike it is and what size motor it is and dose it use a clutch. And dose it use a clutch cause when I got it it was missing the left hand side lever. I got it for $80 it runs but needs some parts. Thanks ImageUploadedByThumper Talk1406134935.796481.jpgImageUploadedByThumper Talk1406134947.995979.jpgImageUploadedByThumper Talk1406134958.862662.jpgImageUploadedByThumper Talk1406134976.712505.jpgImageUploadedByThumper Talk1406134992.128264.jpgImageUploadedByThumper Talk1406135019.635274.jpgImageUploadedByThumper Talk1406135043.065795.jpg
Ok well I just picked up this project the other day and was wondering what kind of bike it is and what size motor it is and dose it use a clutch. And dose it use a clutch cause when I got it it was missing the left hand side lever. I got it for $80 it runs but needs some parts. Thanks attachicon.gifImageUploadedByThumper Talk1406134935.796481.jpgattachicon.gifImageUploadedByThumper Talk1406134947.995979.jpgattachicon.gifImageUploadedByThumper Talk1406134958.862662.jpgattachicon.gifImageUploadedByThumper Talk1406134976.712505.jpgattachicon.gifImageUploadedByThumper Talk1406134992.128264.jpgattachicon.gifImageUploadedByThumper Talk1406135019.635274.jpgattachicon.gifImageUploadedByThumper Talk1406135043.065795.jpg
its some sort if pit bike my guess would be 110-125cc
I had a loncin with a clutch a few years back. The bike was an ander 110 with a loncin motor but most are semi auto. Best way to tell is pull the clutch cover take a pic n post and one of us will know
how can I figure out what size the carb is so I can order a throttle cable??
If its an 80$ bike I'd just replace the whole carb u may find you need to anyway
. The guy I bought it from said he cleaned the carb and changed some seals. Should I still replace it or use it till it breaks.??
At the very least pull the carb apart and re clean it. Just cause he said he cleaned it doesn't mean he did.
alright kool I'll do that today. When I take the carb apart how do I know what size it is so I could order a throttle cable. Thanks again for the help.
I just recently got two 04ImageUploadedByThumper Talk1407912869.850118.jpg honda crf50 frames in a trade ones a rolling frame other is just the frame. I installed the motor I had on the Chinese bike and bolted it on the crf50 (I'll post a couple pics ) I have a problem tho the carb on the engine is almost touching the frame and hardly give me any room to put an air filter on. Would I need to buy a new intake?? Also what size carb will fit on this engine was thinking of replacing it. Thanks.ImageUploadedByThumper Talk1407912785.950571.jpgImageUploadedByThumper Talk1407912819.149521.jpgImageUploadedByThumper Talk1407912832.300103.jpg
