Rear rim offset for 150xc
My buddy is trying to lace a KTM 150xc rear 18" rim.  He didn't check the offset before disassembling the stock wheel and I cannot find the spec after searching.  In case I am using the wrong term I am looking for the spec for how far away the edge of the rim should be from the surface of the sprocket mounting surface so that the rim is properly positioned laterally over the hub.
when it is true on your stand it is good to go
Ok thanks. KTM must be different than my Honda. They actually publish an offset that needs to be set when lacing. Must have something to do with the hub design.
