Difference between 96-99 and 99-01 yz250
I have a 1996 yz250. I want to put the tusk impact rims and hub combo on my bike. Only thing is I cant find them for 96. I can only find them for 99 and up. Are the hubs the same from the 96 to the 99-01? I dont want to order these rims to find out they wont fit.
Thanks guys!
Also if they dont fit what would have to be done in order to make them work?
Theres bound to be measurements on here if you do a search. If you cant find anything, post your hub measurements, message me and ill do the same.
Taken from another thread :
The 1988 through 1998 YZ’s used the 4EW- rear wheel assembly with (I believe) a 20mm axleicon1.png.
The 1999-on YZ’s use the 5ET- rear wheel and a 22mm axle.
The 1996 through 2001 YZ’s all use the same 4SS- front wheel
So how can I make a newer hub work on my 96????
Thanks for your help guys! This is my first bike and its been a bit of a learning curve for me.
