Ignition timing plate 02 250?
I was wondering if there were any other ignition holder plates available for the 2002 style engines?
I have found my plate with a "2" on it. So if there´s a 2, there must be a 1 and maybe a 3 I thought to myself :)
Anyone got info on altering the timing with stock components? I read somewhere that you could file the hole, but maybe there´s a more sophisticated way.
Im pretty sure you can just remove that plate altogether.  Just take out the phillips head screw and remove it.  Then you can adjust timing at your own risk.  I have read in other threads that advancing the timing a few degrees does make a good difference on the 02-04 CR250s.  I have not done this myself however.
