Height Question?
I have just installed some lowering links on my dt125r but when I measure the seat height, it is about 900mm. My dad measured the same height as well so I'm pretty sure that is the right height. But the standard seat height for a dt125r is 885mm. I have never owned the bike with the original link so I was wondering whether 885mm is the height of the seat with the suspension on the lowest setting as there is 15mm difference between the highest and lowest settings. But even that wouldnt really explain it because it has lowering links not standard ones. I cant think of any other reason why the seat height would still be higher than the standard height after installing lowering links. Any explanations?
