What's the best jetting on a fcr39mm MX on a Drz Sm
Hey watsup my fellow hooligans I need some help with this topic I just bought my fcr and had my uncle install it for me but forgot to jet the carb I'm at sea level living in NYC but yea I will really appreciate the info
Where did you get the carb from??
TT store 39 FCRMX
160 main jet....155mj corked
200 main air jet
remove pilot air jet
EMN needle clip 3
45 pilot jet
2 turns fuel screw
O ring or wire the accelerator pump linkage solid and turn the timing screw in a half turn ..
Slant Body 39FCR (OEM E Model)
160 main jet..155 mj corked
200 main air jet
60 pilot air jet
EMN needle clip 3 or stock OBDXP needle clip 5
45 pilot jet
2.25 turns fuel screw
remove the coast enrichener..http://www.thumperta...ichener removal (100 paj with carb ports capped, 60 paj with carb ports linked)
Edited by Craig-o
  • Like 2
Yea ill have my mechanic do it correctly thanks I bought the carb from the TTstore also I'm getting a lot of free play from the throttle is there a way to adjust the cables or do I have to get a motion pro quick turn throttle and cables
TT store 39 FCRMX
200 main air jet
EMN needle clip 3
45 pilot jet
2 turns fuel screw
200 main air jet
60 pilot air jet
45 pilot jet
