Will a 2010 carb fit my 2003?
The total assembly number is not the same, but both carbs use the same components and gaskets, so I'd say yes, if you put the same jetting in, it should be fine.  I've swapped carbs from 02 thru 05 and changed jetting.  I have never swapped between steel frame and aluminum frame before though.
SUNRhu will probably flame me for this!  LOL
Edited by ronbuell
