230 jetting for both summer and winter
2003 crf230. Stock filter, fmf pipe with most of packing gone.
Plug is looking pretty white and little decel popping.
I've been reading jetting on here and the difference in summer temps and winter. I'm in Deep South AL at sea level and now in summer it's 80-100+ degrees. It cranks very easy and have only had to choke it once after sitting 2-3 weeks.
No clue if it has stock jets or not but it seems lean. So what jets can I go to for hotttt summer AND cold close to freezing temps in winter. Thanks
Ok thanks going to tear into it tomorrow. Anyone have a pic of the intake baffle, and what's required?Haven't pulled the seat yet, and not sure best way to remove and what exactly.
Fuel screw was turned out prob 4-5 turns so I'm guessing previous guy tried to get it rich as possible?
So that's the jetting most are running at sea level? With fmf pipe?thanks
Intake baffle is a plastic 'snorkel' of sorts that sits in the rectangular rubber opening at the top of the airbox.Purpose is to quiet intake sounds and it blocks air flow. It's the only air intake opening and it's directly under your seat. Friction holds it in and you just pull it out. If there's just a rubber framed hole then someone already pulled it out.
I like to also remove the 'backfire screen', a four layer wire mesh screen right under your air filter. Makes no sense to me why they need to make it 4 layers, but I'm guessing lawyers have something to do with it. Some day "don't take it out, it doesn't increase hp on the dyno," but in my experience, a dyno doesn't measure throttle response, and without it, I feel the difference!
Do this test: blow as hard as u can thru the screen with your hand on the other side.You can barely feel the air with your hand. If that's not restrictive, I don't know what it is! If taking out the screen will keep u up at night, only remove 3 of the four layers (start from carb side for a cleaner look), it has to help!
Ok thanks fellas. So I can use the stock needle just put it on the 4th notch. Then only jets I need to change are the pilot and main jet?
that should be the case yeah. i find that 120 is a hair rich so i use a 118. im in canada tho so in winter i might have to bump all the way up to a 125-130 lol
FishFreq.. is very attractive what you have recommended about the " backfire screen" removal
Have you done this? Have you raised all the layers?
Surely we will have an improved air flow.
Obviously there is a risk in this mod, even if I believe both remote, a possibility of flame in the air box with consequences potentially dangerous. Do you know if it is happened to a crf230 without the backfire to be burned?
Very little to be gained with respect to an engine requiring maybe 40 CFM of air at best.
Surely Vortec CPI.. I agree, there will be little improvement.
However every small mod added to the other mod will make a good final work. Especially on modded engines with greater air need.
I always remove 2 of the three screens. (Center and carb side)
I leave the one that's next to the filter.
Not having a dyno, I can't go by anything else but the 'seat of my pants' feel VortecCPI. But I'd swear I can feel it. I can measure it by the width of my smile when I crack the throttle!
Yes Crossplayer I've removed the backfire screen from every thumper I've ever had, and so far, no fire alarms pulled. I think if my filter caught on fire, the airstream would pull the flame right out. Don't think a motor can backfire when it's not running so I can't think of any other problems.
It may be 'only 40 cfms' air flow, but with less restrictions, that 40 cfms can ramp up and ramp down faster without obstructions. Some of my bikes have had a coarse single layer of wire as a backfire screen, and it helped on even those, but our crf's have a crazy screen that basically has not one, no not 2, or 3, but 4 LAYERS OF MESH, two of them very fine, with no real good reason for them, other than lawyers. I've never heard Honda, Yamaha, etc., explain why they sell certain 'entry level' bikes with all sorts of baffles, throttle restrictions, and the like other than to stay out of court. It COSTS them more money to sell us motorcycles that are CORKED UP, so it must be worth it. If you choose to remove those items after purchase, then they are legally absolved from any suit.
What's the logic? Anything that I've missed, please point it out.
I look at it this way: if my home's sliding screen door had 4 layers like my crf, that 3 mph breeze cooling my house in the evening is just gonna stop! I mean, why else would passive intake products like the Boyesen Power X-Wing, Loudmouth Air Filter systems, or the 2012 Product of the Year, the Moto Tassinari Air4ORCE tuneable intake system not only exist, but find their way, unsponsored, onto the bikes of so many serious racers? Because they can FEEL the difference! BTW those items are not available for our crf's.
When I took my stock uncorked crf150f and removed the backfire screen as well as ground smooth the huge ugly weld at the head end of the inside of the exhaust pipe, it was amazing! I'm sure in reality it was less than a HP, maybe only .25 hp, but throttle response was definitely up. It's never had any stumbling or hesitation problems so I wouldn't know if it cured that, but it sure made tuning and jetting easier. ....and my smile bigger!
Every tuning situation is different, every rider is different. Friends that have ridden my bike, some of them are so timid, they wouldn't have felt it if I let the air out of the tires! Since we can't see the air and how it's swirling thru our engines, we can't tell if a modification is doing good or bad. So mods like this take a little luck to have work.
To take it out, you have to first remove some white glue Honda put around the edge of the wire, then I used a torch to melt some soldier-like metal at the corners of the attachment. Then I took a dremel with a small grinder bit and smoothed out the soldier burrs. Oh, and this was after I removed the entire airbox, and unbolted the metal filter plate off the plastic airbox or there would be some serious melting going on. Then I soap washed and dried all the parts...
Please note that if you take out your backfire screen out you do it at your own risk. If your bike catches on fire because you did this I accept no responsibility, expressed or implied, by modifications you performed and other factors that could negatively affect the outcome! My lawyer insisted that I include that line!
Where are y'all ordering the 120 jet. I've found the 45 but rocky mountain and Motosport only go up to a 112
FishFreq .. have you raised all the layers? Did not you leave at least one?
Crossplayer, I removed all 4 backfire screen layers from both my crf150f and 230f, I've done this with other thumpers for years with no trouble. How is it going to catch on fire? Neither bike has backfired thru the carb. If timing chain jumps, bike won't run. If the bike is running, any flame will be vacuumed out, IMHO....?
....and yes, completely disassemble the airbox, even the metal filter plate from the plastic shell. You don't want wire frag in intake. If u use torch to melt glue/solder plastic would melt.
Ok .. FishFreq will be my next mod.
Now this becomes interesting to add to my exhaust mod and my bored carb.
Now my best carb setting is 122 main jet. (45pilot + pin in the fourth notch from above in the 05 needle).
You may just need to adjust fuel screw a bit after removal but let me know what you think of all that wire mesh and screen in there, it's nuts!
