Copper washer from oil change
Got to step 9 in the manual, and no pics!! I picked this copper washer out of the oil drain pan. Want to be sure where it goes. I removed the bolt to the bottom right of the case to get the hose off of the screen fitting. Seems to go there. It's a 13' wr250f.
It's probably for the drain plug bolt that drains the crankcase.
See if it fits over it snugly.
The sealing washer for the crankcase drain is copper and the sealing washer for the oil tank drain is an aluminum color and a smaller diameter.
On my bikes, I always use new ones since cranking down on old ones every time might lead to stripped threads.
