YZ85 problems
I ran it out of fuel one day and I let it sit for three days, put fuel in it and fired it up, it hits the rev limiter then instantly drops to half throttle and and back fires then fouls the plug
Fresh fuel, fresh oil proper mix with
My ratio cup,
Hey, my YZ85 is acting like it's not getting enough fuel. Cleaned the carb cleaned the fuel filter cleaned the air filter checked the reeds, just don't know what to do. 2003 YZ85
Did you change the plug a lot assume it's okay because bike is running not the case with 2ts.
could be a cheap fix.
clean the carb.
Check compression, could be time for a top end. If it was on its way out already, might have finished it off leaning it out as you ran out of fuel. How many hours on the current piston?
If it is fouling the plug, chances are its getting plenty of fuel, just not burning it.
Edited by bronc3
