Engine won't turn over
Hey guys just replaced my head gasket, got everything put back together. Installed new coil and plug. Installed crfs only power up kit. Got everything bolted back up and now when I try to start it the starter just spins and won't turn the engine over. Any ideas
It's not getting spark
Got a factory Honda OEM shop manual? if not, get one first.
Reset cam timing and valve adjustment properly this time.
Then recheck compression again.
Good/not good?
If not good then replace bent valves as required and reassemble again.
Let us all know what you find and how it turns out.
