Shim valves 2003 CRF 450?
I just checked my valve clearances. The stock specs for my intake and exhaust valves are: Intake .006 +or- .001. Exhaust .011 +or- .001.
My specs are: Intake right side:.006, Intake Left side:.004
                       Exhaust Right side:.015 and Left side: .012
I was surprised to see my exhaust valves with more clearance than the stock specs. Should I bother with re-shimming the valves or do you think that I could wait until later?
        Thanks for the help.
I was just wondering because I know that when they get really hard to start the intake valves are usually at zero. Since my Left side intake is slightly out of adjustment I didn't know if I had to adjust or if I could run it like it is. Also is in unusual for the exhaust valves to have more clearance than what the manual states. On my right side myh clearance is 4 thousandths more than what the manual states.
