Ktm 85 no spark
I have a Ktm 85sx 2009 model it has no spark. When I bought it it had almost no compression so I replaced the piston ring. Then it no longer had a spark so I replaced the spark plug but it still had no spark. I borrowed a coil from a Ktm 65 and put it in and it still has no spark. What could be the problem? Please Help.
You can actally have another bad spark plug but it also could be the gap between the sparker in the spark uh itself, the two metal pieces that create the spark could be spaced out to far so bend it in a little bit. Hope it helps here is a picture of what I mean ImageUploadedByThumper Talk1406788183.273316.jpg
It also could be a blown fuse or coil problem but your gunna need a ohm meter for the coil to test if it works
Thanks still no spark I borrowed a mates coil and it still has no spark
Sent from my iPod touch using Thumper Talk
Hmmmm I don't know then maybey take it into a shop and get it looked at usually they will look at the bike and tell u what's wrong with it for free but they might charge? Good luck
