Missing tube on carb
I bought a used 2007 KLX110. It's missing a couple things including some tubes that ought to be connected to the carb. One's the drain tube at the bottom of the bowl. That's an easy one. But it also looks like there's supposed to be one on the left side of the carb body.
There's a nipple there that looks like it ought to have a tube connected, but I can't figure out where it should be routed to on the other end.
With the bowl off the carb, there's a hole in the underside of the carb body. If I spray carb cleaner in that hole it comes out this nipple I'm talking about.
Any idea where the tube on this is supposed to go?
Those are drains, get some hose from the hardware store that fits on it securely and run it along the front of the stator cover (left side of engine). There are two tabs that will hold the lines close to the cylinder.
