Tire size
I have a 2009 yz250f special edition its time to get a new rear tire. I know the stock size is 100/90/19. Can i fit a 110/90/19 and what is the benefits or negative effects of running this tire size on a 250
You should be fine. From what I've read, a lot of people do this with both the yz250f and the wr250f. You might experience slightly reduced acceleration with the larger tire, but it seems like no one really notices. You should notice the extra grip though. And keep in mind, it's only an extra 10mm of width and height.
No issue. I actually run a 120 with no issue. Noticeable traction difference between the three tires. 120 is pushing it but it fits.
