Cool trick to know!
Ever have trouble getting your oil filter out? Try this easy method that works everytime!
First grab the rubber piece off your valve stem!
Then grab a paper towel and dry out the center hole in the filter
Then get your needle nose pliers and rubber piece ready.
Stick the rubber piece off the valve stem into the center hole
This helps create a nice grip on the filter, next take your pliers and Insert them in the hole and take your two hands and open the pliers up (this grabs onto the rubber and filter)
Then simply pull it out!
Sent from my iPhone using Thumper Talk
  • Like 3
