MY HONDA WONT TURN OFF!
Alright so i have a honda crf250x which had a baja road package. I removed mostly everything except the display screen and the keyed ignition switch. Yesterday i went to turn off the bike using this swith and it did not turn off!? I had to use a trigger shutoff switch which still works. I then prceeded to start it again without a problem, but when it came to turning it off, once again it did not work! (Mind you it has been running without most of the baja package fine for over a year now, just incase someone had that question) I am absolutely mistified and need some help to figure out how to get it to turn off again. Thanks! Henry
I don't know about the Tusk switch, I used a CRF230F switch. In the off position it shorts the kill sw circuit to ground and opens the circuit to the starter button.  Vice versa when in the on position. Your Owner's Manual should have a wiring diagram with wire colors that will help you identify the Honda wires.
