Linkage questions
Could anyone help me clear up some confusion re aftermarket linkages (in partiuclar Kawasaki KX links)
A couple of questions:
1. If I was to install one, should I go for a firmer/softer or normal shock spring? I seem to find arguments for all three options.
2. The longer linkage is only really needed if you are not revalving your shock, and pretty much a band aid fix until you are in a position to revalve properly
Any comments on the above?
