Project 250
Hey all, just picked up this new to me 06YZ250. This is my first yamaha smoker and it took me awhile to find a clean one that was 06+. Found this one that has a fresh motor top and bottom, OEM crank/wiseco piston. It also has a few other goodies like aftermarket upper triple clamp, pro taper clutch perch, exhaust, and skid plate. I'll be going over it and setting it up to do a good mix of woods,mx, and desert riding. Any advice or suggestions would be great! I'll be starting off with fresh rubber and plastics, open to suggestions from there.ImageUploadedByThumper Talk1406748677.877672.jpg
Get the suspension done and put a fly wheel weight if you want to tame the mid range hit a bit. Other than that nothing needs to be done to these bikes to be the perfect all around bike
The gytr is fine, could put an 8oz stealthy either will work well and do what you want.
Ok well first round of parts are on order- Stealthy 9oz FWW
cycra skid plate
TM Designworks Chain slider and rollers
Wondering what you guys are running for gearing?
Also looking at who does the best suspension work on the SSS stuff.
Thanks!
