Yamaha Adding a brake light to a 01 Wolverine 350
Has anyone does this yet? I have a 01 wolverine that I've had for 01 year and I just thought about adding a brake light to it. I have a raptor 700 front master cylinder on there since the original crapped out so that's the easy part and then I planned on using a banjo bolt style for the rear since the left hand brake works the rear brake but I wasn't sure about the plug/ tail light section. I'm thinking of using a raptor 350 tail light harness to try to fit with the wolverine square lens. For the wiring I was gonna take a power off that is keyed so it's not always on but wire them in parallel to make it come on when either or switches kick in. What do you guys think or is there a better way?
I just found this, that a guy pieced together to use one of the big fat led bulbs.
http://www.yfm350.com/forums/showthread.php?t=22714
I found a new lens and wire harness from 03 wolverine that they put the brake light on so it should be pretty easy now.
http://www.ebay.com/itm/F-New-Yamaha-Tail-Lite-Light-YFM-YFM-350-Wolverine-fx-/390263436401?pt=Motors_ATV_Parts_Accessories&hash=item5add837471&vxp=mtr
Edited by 700rScott
