drz 400 sm high speed hesitation
Ok I know the jetting thing has been covered a million times but my situation is I have a 2014 with full rs2 jd jet kit and 3x3. I am currently use 25 pilot 160 main and blue needle on the richest setting PLUS a shim to try and get the high rpm hesitation to go away. When I'm cruising 70-75 down the highway the bike is jerking. ( hesitating) the reason I have the needle the way I do is because at clip 3 and 4 it was way worse, and was doing it at 60 mph. Now I have it running good at 60 mph cruising speed but the faster I cruise ( higher rpm) the worse it gets. Should I shim the needle a little more? I'm going to ride to Tennessee Friday so id like to try and sort this out first.
I just did 3x3 and rejet and I'm having the same issue. I'm running 25 pilot 165 main with an mrd zpro
