Chain Question
I replaced my front and rear sprockets, and then the chain. The new chain is shorter than the old chain that I'm taking off. Everything that I have seen on the internet shows the new chain being longer than the old one and needing to be shortened by a few links. The back tire was as far back as you could adjust it with the old chain. I had to adjust it most of the way forward to get the new chain to fit. Is this normal or is something wrong?
Sounds normal so far.
When a chain wears, metal is wearing away from the pin/bushing joints, making them all sloppier as time goes on.
This added play in all of the joints adds up to a chain that is called "stretched".
So, when you say the old chain is longer than the new one, do you mean it's longer when measuring it with a tape measure, or that it has a greater number of links?
With a tape measure. Everyone on Youtube had to remove links, so that's what I was expected.
Sounds like everyone is simply buying a chain that has more links than needed.
That's pretty common since a lot of places stock 520-pitch chains that are 120 links long.
The typical dirt bike is around 112 or 114 links long.
I got mine there too. Rocky Mountain ATV is my local store. The one I bought is 112, so it sounds like i'm OK.
