Helppp! Question about 07 kx450f inner clutch cover?
Ok so i need to replace the kickstart mechanism and i know i need to pull the clutch cover, basket etc. out, but my question is will i need to remove the water pump cover and impeller to take off the inner clutch cover? Or can i just take the inner clutch cover off and reinstall it without all the extra hassel?
It can stay on
I found it easier to remove the impeller when I had a kickstarter issue; significantly easier than removing the clutch basket. When reinstalling the inner cover, the impeller has to be lined up just right to fit into the balance shaft notch. With at least the water pump cover off, the impeller can be turned with your fingers to the proper position.
