2003 Yz 125 rebuild
So far pretty much stripped it down. Got parts in today cylinder looks good not sure how important honing is but I should probably pick up one.
Got some time today finished the top end, radiators, carb, and got the shock and linkage greased and installed. Ofc a ton of scrubbing the years of crap off the parts, still a ways to go.
What do you use to clean the frame? Also, I know a lot of people powdercoat their frames but is there any other type of paint that can be used? Something that is kinda durable? I have a 2002 Blaster that I am rebuilding but I am on a budget. I would rather spend the $$ on performance rather than painting the frame. Thanks!
Scotch bright pad and soap for the frame I wanted to powder coat but kinda expensive and I'm not sure about the paint.
All finished carb had a bad seal was in the float valve. Took a old one from my 250f that I had extra was a tight fit but works fine, cranked it up rode around a little runs good compression is high. Got to work on the jetting its jetted for sea level and I'm at 6500 feet. Time to ride tomorrow.
