06 klx110 forks
As most of you know, the stock 110 forks suck. I was wondering if anyone has used kx65 forks on a 110. I have heard you can but worry they'll be too tall.
Or would it be worth buying upgraded springs and dampening rods.
...yes, very common upgrade.  see the Chinese and KLX110 forums on here and on planetminis.
u can also cut your springs to firm them up and run 30wt oil / 80-90wt gear oil as a fork fluid, which is a darn good improvement, itself.
this works on both KLX and KX forks.
if u do buy KX forks, try to find the ones with rebound-adjusters on them, they do help.
cut springs?? no thats just not right.  what he should do is go to tboltusa.com get some stiff springs and throw in 15wt fork oil   that makes the forks very good  im 185 and they handle me
