YZ250 Evo Flywheel Compatability
Hi there ,
Does anyone know which flywheel will fit my 1988 YZ250U ? From the OEM parts catalogue , only '87 , '88 are the same part number / construction.
If the internal diameter is the same as my '88 OEM flywheel , will a later model fit ? The pickup coil is inside the flywheel , so it looks like a '92 , '93 is similar. Anyone have any previous experience ??
Cheers my dears ,
  • The crank case # is superseded to this so these stators will definitely bolt up to your case and I'm sure the taper on the fly wheels didn't change from 83-94.  Mixing and matching fly wheels and stators might not work as well don't mix and match stators and CDI boxes with out knowing what your doing.
1996 WR250ZH - Crankcase
1996 YZ250H1 - Crankcase
1997 WR250ZJ - Crankcase
Edited by BruceD_500
