difference forklegs
do anyone know if a insert ( cartridge) from a 2010 honda (kyb 48mm ), works in kx450 20144 (kyb48mm) forklegs ,basically same fork . i got the inserts with springs from a honda crf 450 10 and was thinking about a conversion to spring fork, if  i dont get the airfork working like i want them to ,in my opinion it should work , opinions??
Your premise is very close. However, there are some differences among these models (2010 crf450 & 2014 kx450) that wont allow this to properly work.
1. The cartridge lengths (on the 10 crf450 and 14kx450) are different
2. The axle lug design are different
3. Hydraulic locks wont match between both models
These key differences will unfortunately keep you from being able to achieving this.
Hope this helps out!
Edited by Bryan Bosch
yeah i saw that when looking in ohlins catalouge it differs 6 mm in length so i dont work axle lug wouldnt been an issue since i was gonna use the outer /inner forklegs from the 14 just use the internials froma honda but as said it wouldnt work ,thanks anyway
