****Crf 150r fork seal replacement help ****
I am replacing my front forks after seal started leaking. I am currently experiencing trouble getting the basebolt on the bottom of my forks off. It spins but does not want to come out it's the same for both forks what am I doing wrong
Pick up a 24" length of 3/4" square aluminum tube at your local hardware store. Use it to hold the cartridge by sliding it down the damping rod to engage the spring perch. Then you can remove the bottom bolt without the cartridge spinning.
I got my bottom bolt out by compressing the shock but my problem is getting it to tighten back up. I compressed it as far is I could but still couldn’t get it to tighten like it was before. Any suggestions or is it not possible to get it as tight as it came from factory?
