losing oil 13 250xc
I have noticed that the tranny is losing oil on my 250xc. I imediatly thought it would be my crank seal, but after searching I found others were having symptoms. My bike runs fine, no excessive smoking, and no spooge on my silencer. I dont see oil leaking out of the motor anywhere, or on my garage floor.
Could it be the crank seal, and everything operates normall? Can the seal be replaced on this machine without splitting the cases? The bike loses about 75-150 cc every two hours of race conditions. I have never had this problem before so any advice, or past expierences would be greatly appreciated.
Are you sure the leak isn't coming from the counter shaft seal? That is a pretty common place to get a leak, and an easy fix.
I did check the counter shaft, no leak there.
