06 yz450f dies when i pin throttle
ok so i have an 06 yz450 f iv been trying to tune this dam thing for days...
my problem is when i pin the throttle as fast as i can it bogs and dies..
 if i do it smooth and fast it revs up great! but like i said pin it and it dies...
 i have messed with everything and it wont go away
it looks like it has a stock exhaust with a lexx xc screen type usfs 12-007c  tip
42 pilot jet
3rd from the bottom dyno jet needle
46 main
2 1/2 out on mixture screw
looks like an aftermarket air filter but im not sure  its green haha
right now it runs the best like i have it , do they all do this or am i doing something way wrong??
iv tryd every clip position possible with the dyno jet needle and a NFP R needle
also has the ziptye mod but im using an o ring ,
help im lost....
also of been reading everything on line so iv done my research but still not sure..
Jetting is way off, but regardless, it is normal to get some bogging if you WOT very quickly.
The issue is Accelerator pump tuning, not jetting.
Needle has nothing to do with it
You should be running
45 p
165 m
NFPR on 3rd
50 leak jet
*new* accelerator pump diaphragm will help emmensly.,
If you want more detail read and do this:
http://www.thumpertalk.com/topic/552436-installation-of-rd-powerpump-on-keihin-fcr-carb-yfz450/#!HhZ2a
45 p
165 m
NFPR on 3rd
50 leak jet
ok thanks for the help i will put everything how you say and see how it is , im new to the carb tuning hopefully i get better at this...
ok now i have the clip on the 3rd position a 65 main and a 48 pilot
it poped so bad with the 45 pilot
so i got a 48
it still pops just not as bad
i cant get that to stop poping...
runs good tho
any ideas ? messing with the mixture didnt do anything...
You make no mention of the fuel screw....which is what you adjust BEFORE changing pilot sizes, specifically to determine the size you need.
Read the description at the top of the forum
