94 kx250 oil help
I just purchased a 94 kx250 and the person I bought it from said he changed the oil not too long before. Just to be safe I tried to change it but the drain plug has been welded over. The original owner said he did it because the bolt was stripped and he just used a pump to get the oil out. I tried that and I'm not getting any out but the level says its full. It still runs but I want to be on the safe side and put in my own oil.
Friggin Mo-chanics, idiot should have used a heli coil. Your going to have to grind off the jb crap he probably used and EZ out the bolt. I just did my rear tire popped on a 606 and also changed my oil to boot! I still use Golden Spectro full synthetic for all of my bikes. Still the best imo for two stroke and 4's.
Good luck!
