350 exc error code
Just had a big mtn ride and went down hard. Had to kick start the hell out of 350 exc. To get it started. FI lamp was flashing short flashes but could not could them all short flashes. Owners manual say manifold absolute pressure sensor cylinder 1- input signal too high/low. What does that actually mean?
There is a pressure sensor on the throttle body, check if maybe a wire for yanked out in the crash that leads to the throttle body.
Two quick questions. Will it still run with the sensors on the throttle body disconnected and where os the throttle body? Thanks for the info!
I don't know if it will run with that wire disconnected, but follow the throttle cables and they lead right to the throttle body.  It's where the carburetor would have been if it was a carbureted bike.
