Need help taking carb off
Bottom one first, I believe.  Loosen the forward jam nut (the one on the right in the photo).  Slide the cable assembly from the carb housing.  This gives you just enough slack to remove the cable ends from the slider wheel.  Rotate the wheel to get the upper cable off.
Yep, u need to rotate the wheel (towards the front of the bike) and hold it in place while u pop the upper one out. The lower one as he he said comes right out after u loosen up the nuts and slide it out of the groove.
