2000 kx125 idler gear/primary shaft
I'm working on re-building a kx125 that's been in pieces behind a friends house for over 6 months. I'm stuck on the kickstart idler gear now because the groove on the shaft for the clip to go in gets covered by the gear when you put it on. the shaft doesn't move in or out to make enough room for the gear to sit on it while still allowing the clip to hold it on and i dont know what to do to fix this problem. any suggestions would be appreciated
