Swapping a 'K' CDI Box onto an 'E' Model?
Greetings. I've been chasing other projects over the last few years (turbo Hayabusa, Urals, KLRs, SV650s, BMWs, etc..) but I've got a question that hopefully the the more DRZ-centric can answer for me.
I've got a 2000 'E' model that supposedly has a bad CDI box. My research says that my ('99 or '00) 'K' model box will work but may need some rewiring at the plug. Sounds like when I swapped the Hayabusa from '99 electronics to the '05 box and rotor.
Is this correct? If so, what's the rewiring required?
Here's the 'K' box...
9D0C6452-2BE7-4CDD-A1F1-951F7A94D35C_zps
Thanx,
Weazel
E and K CDI, should need no changes to swap.. Only the S/SM and others.
And that box/ number above.. Not something normally seen on a DRZ400 CDI
That is most likely a aftermarket CDI.. so all bets are off as to if it will work or how.
Have a look at the CDI ID guide
DRZ400 CDI Identification
Started by E.MarquezDec 02, 2013 11:03 PM
http://www.thumpertalk.com/topic/1058295-drz400-cdi-identification/
All OEM CDIs are Mitsubishi brand and the ID numbers are in three separate lines stacked one on top another
