'81 XR500R needs top end work
I had an '82 xr500 that I did head work on. The valve covers should come off no problem. You will have to remove the engine to get the head off though. I didn't get into the jug on mine but assuming you will need the engine pulled for that too. Best wishes
OK, turns out the motor has to come out to pull the rocker cover off.
I took the 500 apart tonight. It leaked oil like a sieve and had some funky stuff going on like a tire valve instead of the flat plug that goes at the end of the cam shaft.
Also, the last time I used it I had a hard time starting it back up and there was an awful noise coming from the valve train.
There was a screw floating around in there... and I have no idea where it came from???
10467134_10154418104190487_3582276700581
10524214_10154418103995487_8341864899663
