Kx250f
I've got about 600$, I'm trynna make my kx become faster and stronger, what are some good things to add so I can increase the speed and power on it? Oh yeah and I've installed some pro taper handlebars on it, do they make the handling better?
Put SSS suspention in it. Iv got that on mine and it made the bike so much smoother in corners and every were els. Put a pipe on it i recomend yoshimura or procircuit and rejet it for that pipe
Spending $600 on your suspension won't give your bike more power but it will have the biggest affect on decreasing your lap times
As mentioned suspension first
Make sure the motor has been rebuilt recently and jetted for the altitude
Seen so many badly jetted bikes that people are adding cams to and porting heads when all they need to do is fix the jetting.
Suspension as in like make it my setting and for my weight, or buy aftermarket suspension forks? Should I change the rear shock as well?
