2013 kx 450
I have a 2013 kx 450 and the launch control light stays a solid light..... Any suggestions on what it could be??? Thanks!
Manual says DFI system or ignition system parts faulty.
Should point out that's a 2012 manual.
Edited by Koog
Get a new spark plug from your local dealer.replace plug. Above the left radiator unplug the ground. Start the bike and ground the ground to the frame for a little bit and run bike. Run for 2 minutes or so. Read the blink code. Unplug water temp sensor in back of cylinder plug back in. Start bike. Maybe possibly? Has worked 2 times but ha failed once.
