CRF450X Wiring issues
Gday guys just wondering what these two wires are? I removed the front headlight plate and found these two wires hanging there. I've only had the bike for a week and trying to work out what the previous owner has done.
The brown wire has constant 12v power where as the grey wire with green stripe has now power what so ever.
Cheers
Have attached a photo of mine which shows which coloured wires they connect to. These wires run up to the main handle bar controls with a heap of others.
I would say they are part of the safety switch eg have to pull in clutch to make bike start
Hope this helps
Bike won't start unless clutch is in though :/
It has an aftermarket speedo though a vapour dash. Everything works on the bike as it should though just unsure of this loose wire
I have an 06crf450x with a Vapor and I have those hanging down too.  not sure what they are though
