02' yz250f JD jetting?
Ive got an 02 yz250f runs pretty good but has a lil bog from time to time, im gonna put a JD jets in it since ive heard so many good things about JD, but im a total carb rookie tho the most ive done to my carb as take the bowl off to check the float, can anyone tell me does the JD kit come with every kind of jet i may need and if not what is a good setup to start with, what size main jet. leak jet, etc... thanks
It comes with all the jets you need...JD kits are simple to follow due to detailed instructions...JD "magic" is all in the needle shape...and there is a settings list that JD prints in the instructions for a stock motor at high altitudes or a " free flowing" exhuast for sea level for example...
Edited by deafrider250f
