Help
Hi I have a 2013 RMZ with 16 hrs on it and after changing air filter  in preparation for a race it will not fire up. It has had a clean air filter installed after every ride and oil changed every monday after a race with a new filter every other. Compression is still really good didn't test but it still takes a strong leg to kick it over.
I have checked spark and it seems fine. Tried a small dose of starting fluid dint even try to start
No when I got home today and was able to look at it in the light instead the dark I noticed the TBI had pulled away from intake when the sub frame was removed. It was an easy fix, thank you for your reply, removing the filter was the first thing we tried to no avail.
