PW 80 won't run under load !
So .. I have had the carb cleaned and set up at a shop for the second time now ! And still have the same problem : (. It idles perfect and you can rev it up and sounds good , as soon as you put it into gear and give it some gas it stalls , as soon as it is out of gear you start it again and idles fine ! At a loss don't know what to check ? Could the CDI OR COIL be my problem ?? Any help would be great !!
So it starts ok, idles and revs out.
If you elevate the bike and put it in gear with no rider and rev it out what happens?
Does it stall? OR is it only stalling and not revving out when there is a rider on it?
Doesn't sound like an electrical problem.
I would first check the carb needle height and then the air screw setting.
Sounds like the bike is running lean somewhere or there is a clutch issue.
Keep me updated.......Miller
Edited by miller234
We'll I was toying around tonight with it tonight ,and figured it out ! Found a short in the kill switch wires !! Lol. Unplugged it at the CDI and works great ! Thanks for all your help :) this site is great
  • Like 2
