Piston and rings
They are as long as you install them right and set the ring gap to the manual specifications. They usually only fail because the user didn't ensure they were installed correctly and in spec because all they did was drop it in.
Make sure you set the ring gap and everything is in spec with your manual and you should be fine.
If you haven't bought it yet and don't wan to take chances, get OEM, which I believe is Vertex.
