Screaming high rpm at idle
Hey guys
I have a 2004 honda crf250x with an open air box that is screaming high rpms at idle. I have a 42 pilot and a 158 main. The bike sat for several years. I cleaned out the carb. The high rpms happened before it sat this last time. I can't quite remember when they started.
Help is greatly appreciated.
You will have to be more specific as to 'cleaned the carb'
More than likely, you still need to:
Service/clean/decorode the hotstart, choke, and apump system
Replace the pilot jet
Replace the slide seal
Lube the idle cable so it doesnt' bind
Add an R&D remote fuel screw so you can properly adjust your fuel screw at idle
http://www.dirtrider.com/features/protips/141_0707_keihin_fcr_carb_rebuild/
Kah ran née,
Thanks for the quick reply. The pilot and main jets are clear of any junk but after reading the article it will just be better too tear it all apart and redo it. I'm sure I missed stuff. At least I have the fuel screw!!!
