WR300: Do I have to change the piston soon ? (pictures attached)
Hi all,
yesterday I took the pipe out and made some photos of the piston, please have a look:
Bike is a WR300 2010, I bought it second hand and don't really know the hours / kms on it, seems to be the original piston.
I think the piston is not too bad, machining rings are still there on the skirt, there is a spot under the second ring that is shiny.. I think there is some blowby also and a lot of carbon deposits on top of piston and power valve. My jetting was way rich and I'm using a high flashpoint ester oil at 2% mixture.
What are your insights ?
Thanks.
The piston visually doesn't look bad, but as robertaccio mentioned, there is a good amount of blow by past the rings. Pull the piston, mic it out and if necessary, replace piston and/or rings.
