Xr600 chain/sprocket issues
I put a new rear tire on my bike and I can feel the chain skip when I hit it in a low gear or in a high gear and going slow when it lurches forward. I got the tire all lined up and everything, no matter what I do there is chain noise and skipping. I oil it every time I ride. I got a new 15t front sprocket before the tire swap and it worked fine till I swapped the tire, now I hate to ride it for fear it will blow off since I can't fit the case saver and front chain guard no more thanks to the PO's shitty work. I'd the front sprocket suppose to wiggle at all? Seems to have a little wiggle if I tug on it in different directions, its brand new. I didn't notice if the old one wiggled or not... thanks again guys, probably an over asked question sorry. Also back brake doesn't work at speed for some reason
Edited by 600thumper
good you found the problem before it threw you off and ruined a bunch of shit.
