XRR Front fork compression shim stack removal
About 3 years ago I had my front forks serviced/modded per the Borynack file by an outside shop.The forks are very harsh on baby-head rocks and I am suspecting something wasnt done correctly.My question-can I remove the compression stack from the bottem of the forks with out dissassembling anything else?
On most conventional forks at least, yes you can flip them upside down.  However, if you have something wrong with your setup you may want to do a complete disassembly to check everything.
