oil change and check bolt
I'm helping a friend on her 2009 rmz250. I changed the oil like my rmz450, took out allen bolt, screen and kicked to drain the sumpp. I'm being told 950ml but alot more than that came out. Does this bike have a check bolt to verify the level
Yes. Back of clutch cover on case. I Dont use it. I just measure oil and dump it in. My 13 is 1200ml I think. If its too much it will blow out vent tube. If you put too little in..well,then you got less oil.
