A Kit suspension for Crf 450 2013
Personally I'd go with a A kit. A true A kit is gonna cost close to $10k with everything you need.
Hi, I want to buy a suspension for my bike, and I'm not really sure what to do. Ohlins, A kit, race tech valves. Independent of money cost, what do u guys recommend?
i would recommencement an enzo setup which have a lot off experience with the psf as is or an MX tech setup which is quite more expensive!
the ohlins will still need to be send out to be setup for you unless you get a deal!
the one i rode was not better than a revalve
For the cost of true a kit, you could get ohlins front And back and set up.
You could try a longer kink arm too I think it is in the back for more control in the bumps. Personally I would get your standard suspension revalved and sprung for your weight and ability. Not even all pros use a-kit as they don't like the feel of the forks. Unless your a class or pro, you probably don't need a kit and will be more than ok with standard setup well.
