Rear brake light operating spring 1995 model
Can anybody tell me if mine is fitted properly ?  The switch is mounted on a frame tube above the pedals falcrum. It looks factory fitted and correct. There was a short spring connected to the foot pedal from the switch. The problem is that the spring is connected to the top of the pedal above the falcrum (the pivot point) of the pedal and when you apply the brake there is ] no downward movement.it only turns . I have a feeling this spring should be attached to the pedal somewhere else?? But there is nothing obvious.
I know about hydraulic switches but as my switch works and I have so much to do to the bike. I would like to use this switch if I can.
Any help appreciated
Marcus in England
